Help cooling plz
Go to solution Solved by Skiiwee29,
Just now, Ardu said:
I am indeed, but the 9700k doesn't come with a stock cooler, and I think it's time for an upgrade anyway.
mmmmk, you are correct it does not come with a cooler and the stock cooler you have now on the 6700 will fit it, but you will have a bad experience thermally with the chip. So the H440 has a CPU Cooler clearance of 180mm so pretty much any tower cooler will fit on it. I would personally go big and go with something like the Dark Rock Pro 4, Noctua NH-D15 or Cryorig R1 Ultimate myself. These 3 are the best tower coolers on the market and will perform as well, if not better than many 240mm AIOs on the market.
I think this goes here. I need some help. I'm getting a 9700k soon, and would like to know how I should go about cooling it. My specs are in my signature, my case is the NZXT H440. Also I am aware my current MOBO doesn't support the chipset, I have already purchased a Z370-A so I'm all good for that.
Thanks in advance! :)
Current PC
CPUIntel Core i9 9900k
GPUGTX 1080 8GB FTW EVGA
MotherboardASUS PRIME Z370-A II
RAM: Corsair Vengeance LPX (2x8GB) DDR4 2400 Mhz
Storage 1: Samsung 850 EVO 250GB
Storage 2: Hyper X 240GB
PSU: Corsair RM750 80 Plus Gold 750W
Peripherals: Logitech G502 Hero//Corsair K70 MK 2 Cherry MX Red
Display: BenQ XL2430T 24-inch 144Hz
https://linustechtips.com/topic/1066271-help-cooling-plz/
What are you using now for cooling, the stock intel one?
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1066271-help-cooling-plz/#findComment-12589495
Current PC
https://linustechtips.com/topic/1066271-help-cooling-plz/#findComment-12589499
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1066271-help-cooling-plz/#findComment-12589507
You're a star, thanks for the help my dude! :)
Current PC
https://linustechtips.com/topic/1066271-help-cooling-plz/#findComment-12589510
