Can't put my fans on low rpm
Lord DN
I have 4 fans connected to my NZXT Kraken X62 and they go all the way from 25% to 100% pwm. However my Strix 1080Ti decided that it won't let my Asus FanConnect-ed fans spin at anything lower than 44%. Does anyone know how to make it go lower/edit the config file that has that 44% number saved somewhere? They're the same fans (Noctua NF-A14 iPPC-3000 140mm PWM) so I know they can go lower.
If I understand you correctly you should use speedfan and control your fan speeds granted its 4 pin connection
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
I'm not sure if you can actually use something like speedfan to control it as the fans are controlled through the GPU as I want them controlled by GPU temps.
Oops sorry I thought your talking fans on case or CPU HSF.  If you want to control the GPU temps and set a fan curve then grab MSI Afterburner.
Afterburner can control the fans through the fan headers on a Strix card? I actually have nothing plugged into my motherboards case fan headers, but if afterburner can control those with gpu temps I'll just go with that
