On 4/7/2019 at 3:34 AM, rawrturkey said:
when i shutdown or put my computer to sleep there is a constant ticking sound, all of my fans turn off like normal apart from the ones connected to the h100i the led on the h100i also keeps flashing any tips will be a giant help
clicking hard drive maybe? the radiator fan needs to be running otherwise the cpu will overheat.
(◣_◢) Ryzen 5 3600,   Aorus X370 K7,   XPG 16GB 3200,   Gigabyte 2070 Windforce Corsair RM650x,   LG 32GK650F-B 31.5" 144Hz QHD FreeSync VA,   Kingston 120GB SSD,   Samsung 1TB 860 QVO,   2TB HDD,   Fractal Design Meshify C,   Corsair K63 Wireless,   Corsair Gaming M65 PRO,   Audio Technica ATH M50x,   Windows 10 ProCorsair H100x 240mm.  (◣_◢)
(◣_◢) Ryzen 5 1600,   Noctua NH-L12S,   Gigabyte GTX 1060 6G,   ASUS Prime B350 Plus,   HyperX Fury 8GB DDR4 (2666MHz - 1.3v),   SilverStone ET550-B,   Kingston 120GB SSD 2TB HDD,   Cougar MX330,   Windows 10 Pro.  (◣_◢)
https://linustechtips.com/topic/1052226-clicking-sound/#findComment-12462423
i did not think of this as an option the strange thing is the case fans keep ticking over aswell they spin for a second stop then keep doing that in time with the clicking
https://linustechtips.com/topic/1052226-clicking-sound/#findComment-12462428
