So, I've got a new build I've been working on, specs are:
AMD Threadripper 2920x
Gigabyte Aorus Pro X399 Mobo
MSI RTX 2080 Ventus 8G
(2x8) 16GB DDR4-2666 RAM (don't have enough for quad channel on a quad channel mobo but that shouldn't be the issue)
500gb Crucial M.2 NVMe
256gb m.2 nvme
3TB Seagate HDD
When I power on, I get a post code of 16 and then it goes through some other codes and back to 16 on a loop. The CPU LED is red immediately, and the fans all spin up but nothing really happens. I get nothing on the monitor, but the keyboard does light up. Any ideas?
https://linustechtips.com/topic/1046630-tr4-mobo-cpu-issue/
What does Post Code 16 mean? Chances are the CPU needs to be re-seated. its a common problem with threadripper.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1046630-tr4-mobo-cpu-issue/#findComment-12412183
