Hi I am trying to use the wiring pi library to use a stepper motor with c++ for a project in my engineering class. I am not very experienced in programing so I tried to basically convert the code from a video that used python into c++, I am using different pins however but that's the only way i could get it to feel like it was trying to move. I can feel the motor trying to move but it's not actually moving any visible amount.
video:
my code:
#include <wiringPi.h>
#include <iostream>
using namespace std;
void Sleep()
    for (int i = 0; i < 1000; i++)
int main(void)
    wiringPiSetup();
    int uPin[4] = { 5, 6, 10, 11 };
    for (int i = 0; i < 4; i++)
        pinMode (uPin, OUTPUT);
        digitalWrite (uPin, 0);
    int seq[8][4] = { {1,0,0,0}, {1,1,0,0}, {0,1,0,0}, {0,1,1,0}, {0,0,1,0}, {0,0,1,1}, {0,0,0,1}, {1,0,0,1} };
    for (int i = 0; i <= 512; i++)
        for (int step = 0; step <= 8; step++)
            for (int pin = 0; pin <= 4; pin++)
                digitalWrite(uPin[pin], seq[step][pin]);
                Sleep();
                cout << "slept \n";
    return 0;
https://linustechtips.com/topic/1043296-raspberry-pi-c-stepper-motor/
