1. Budget & Location
1000€ EU, Lithuania
2. Aim
Play newest games. For ex. Cyberpunk, BF5, Anthem, Metro Exodus, Far Cry. MMO'S, RPG'S
3. Monitors
1x - BENQ 24" XL2411Z LED PIV
4. Peripherals
 Windows 10. I am using Corsair's RGB keyboard if it gives any difference.
5. Why are you upgrading?
The PC I have now has, 3.5 ghz CPU, 2GB GTX 960, 8 GB RAM. Sorry I forgot all the details but I can give them if you need.
I've picked something like this. I just want to know If this can be maybe cheaper by changing some parts :/ or change with parts that are more reachable
https://linustechtips.com/topic/1027215-building-my-first-pc/
  Intel® CORE® i5-9600K 3.7-4.6Ghz, 9MB cache, 6 core
  Cooler Master Hyper 212 Evo
  MSI Z370M MORTAR Twin Turbo M.2, GAMING LAN, Military Class 5, EZ Debug LED
  G.Skill Aegis DDR4 16GB  (2x8GB) 3000MHz
  Kingston SSD A1000 M.2 2280 NVMe, 480GB, up to 1500/900MB/s
  MSI GeForce RTX 2070 GAMING Z 8G, 8GB GDDR6
  Dual Realtek® ALC892 Codec7.1-Channel High Definition AudioSupports S/PDIF output
  NZXT H400i Matte Black/Blue
  Chieftec PROTON BDF-650C, 650W, 80 Plus Bronze, Modular
This is what I fount in my country for 1500€ :D
https://linustechtips.com/topic/1027215-building-my-first-pc/#findComment-12244122
2 minutes ago, Manderis said:
I would not go 6700k and 1080 (also not in stock)
The m.2 250 GB SSD doesn't make much sense at that pricepoint. Go SATA. Can you buy from Amazon Germany? So I can check pricing there for you
I tried but I got blocked two times in there :D
https://linustechtips.com/topic/1027215-building-my-first-pc/#findComment-12244263
You can just add parts you think is best for games and is not overexpencive and I will check in my country stores.
https://linustechtips.com/topic/1027215-building-my-first-pc/#findComment-12244268
PCPartPicker part list: https://pcpartpicker.com/list/VswzLJ
Price breakdown by merchant: https://pcpartpicker.com/list/VswzLJ/by_merchant/
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($165.98 @ Newegg)
CPU Cooler: ARCTIC - Freezer 33 eSports ONE (Black/Red) CPU Cooler  ($33.12 @ Amazon)
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard  ($111.74 @ B&H)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  ($109.99 @ Newegg)
Storage: Crucial - MX500 500 GB M.2-2280 Solid State Drive  ($57.99 @ B&H)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($59.89 @ OutletPC)
Video Card: MSI - GeForce RTX 2060 6 GB VENTUS OC Video Card  ($349.99 @ Newegg Business)
Case: Fractal Design - Focus G (White) ATX Mid Tower Case  ($57.98 @ Newegg)
Power Supply: Corsair - RMx (2018) 550 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($59.99 @ Newegg)
Total: $1006.67
Generated by PCPartPicker 2019-01-29 10:12 EST-0500
You will probably not be able to find all the parts. Do you need an optical drive? Just include one. For PSU quality use the PSU Tier List because not all models are available in every region. Just take something Tier 3 or better with 500 Watt or more.
The 2600 is just 150 $ cheaper if you consider CPU and Motherboard price compared to a 9600k so i think it is best to invest your money in a better GPU
https://linustechtips.com/topic/1027215-building-my-first-pc/#findComment-12244330
Total: $1006.67
Oh ok so can I just put a little better cpu and video car ant I would pref Intel :)
https://linustechtips.com/topic/1027215-building-my-first-pc/#findComment-12244552
Total: $1006.67
I am looking at games requirements ant trying to fit in them
https://linustechtips.com/topic/1027215-building-my-first-pc/#findComment-12244555
PCPartPicker part list: https://pcpartpicker.com/list/XwZwvn
Price breakdown by merchant: https://pcpartpicker.com/list/XwZwvn/by_merchant/
CPU: Intel - Core i5-9600K 3.7 GHz 6-Core Processor ($259.99 @ Amazon)
Motherboard: MSI - MAG Z390 TOMAHAWK ATX LGA1151 Motherboard ($153.42 @ Amazon)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory ($109.99 @ Amazon)
Total: $1142.36
Generated by PCPartPicker 2019-01-29 13:10 EST-0500
Here you go with Intel.
A better gpu would depend on your monitor. If you only want 1080p @60 Hz or even 144 Hz a rtx 2060 is plenty. If you have a 1440p monitor you might want to look into something stronger. If not and you don't plan to it is kind of a waste of money.
https://linustechtips.com/topic/1027215-building-my-first-pc/#findComment-12244805
Total: $1142.36
THX Bro
https://linustechtips.com/topic/1027215-building-my-first-pc/#findComment-12245086
