System Restore not working properly on Winblows 10 help!
Turtle Rig
Ok system restore works but when you go choose a date to restore your registry it just sits there saying recovering registry or something like that which is the normal screen you see when you run system restore,, but when I go restore it like I said it just hangs on the screen and hour glass thingie saying recovering registry or whatever it says,,,, and does nothing.  I tried in Safe Mode as well and doesn't work,, gets stuck on the screen that says restoring registry and what not.
What is up with this,, I neeed to do a system restore right now,, faaaaaaaaaaaak
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
