The PSU is a piece of blast-tastic crap. Let us help you configure a rig. What is your budget and location? Do you need an OS, monitor or peripherals?
Otherwise, get a Corsair CX600M.
https://linustechtips.com/topic/102170-help/#findComment-1366348
How much watt is it? If it's over Around 500-600w, you'll be fine
CPU: FX-8350, GPU: xfx radeon r9 290, RAM: corsair venegance 8gb, STORAGE; seagate barracuda 1TB hdd, SSDnow kingston 120gb, CPU COOLER: CM hyper 212 , CASE: fractal design XL, PSU: corsair CS 650w 80+ gold MOBO: Gigabyte GA-990FXA-UD3
https://linustechtips.com/topic/102170-help/#findComment-1366351
http://www.newegg.com/Product/Product.aspx?Item=N82E16817159129
https://linustechtips.com/topic/102170-help/#findComment-1366359
I think there is a clue in the model number.
yeah just saw it
https://linustechtips.com/topic/102170-help/#findComment-1366379
Is a coolmax zu-700b good enough for a geforce gtx650Ti (2gb) ??????? Trying to get the best start off gaming pc out there... Looking toward to playing dayz etc... Please help!!! Thanks!
Anyway, yes it's enough in terms of wattage, more than enough in fact. However, perhaps you should pick another more trusted brand. Corsair, Rosewill, Coolermaster, NZXT, Fractal
https://linustechtips.com/topic/102170-help/#findComment-1366396
