Unless your'e getting the 5 gig 780 I'm pretty sure a 384 bit bus will be just fine.
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/101964-384-vs-512-bit/#findComment-1363729
My question is if a 780 was 512 bit bus would it make a difference?
well, if the 780 was 6gb like the titan, yes it would make a big difference
as it would mean you could use more of the Vram avaliable too you,
generally speaking, 2gb = 256bit bus
its been discussed on the forums plenty of times that 4gb with 256bit bus couldnt use all the Vram avalible, so 3gb = 384 bit and 4gb = 512 bit
The Beast [Case -  Corsair 750D CPU - I5 4670k @ 4.3ghz 1.2V CPU cooler - Hyper 212 evo Mobo - MSI g45 z87 RAM - G.Skill Z series 4*4@1866mhz GPU - Gigabyte windforce 3x r9 290 Storage - SSD, samsung 840 evo 120gb HDD, Western Digital Blue 1tb PSU - SilverStone Strider silver 80+ 750WPeripherals [Monitor - ASUS VS239 IPS 23" Keyboard - Corsair K95 Mouse - Mad Catz RAT 7]
https://linustechtips.com/topic/101964-384-vs-512-bit/#findComment-1363730
If there were more vram it would help
CPU: i5 3570k CPU Cooler: Hyper 212+ Mobo: Asrock Pro 4 Z77 GPU: Sapphire Tri-X R9 290 PSU: Seasonic G 650w HDD: Seagate Barracuda 1TB SSD: Kingston v300 Sound Card: Asus xonar dg MonitorAcer K272HUL, HP 22bw
Keyboard: Corsair K70 Mouse: Logitech G400 Mousepad: Steelseries Qck+ Case: Corsair Air 540 Fans: 4x Noctua NF-P12 (saving up for more)
https://linustechtips.com/topic/101964-384-vs-512-bit/#findComment-1363732
Only if the memory clock stays the same.
290 has 512bit but only runs at 6.0Ghz compared to 780 that has 384bit but runs at 7.0Ghz.  At the end of the day they are pretty much equal.
CPU: i7 4770k @ 4.3Ghz with NH-D14 | RAM: 16GB Corsair Vengeance 1600MHz | Motherboard: ASUS Maximus VI Hero | GPU: SLI GTX780 Windforce | SSD: Samsung 840 Pro | HDD: WD Black | PSUEVGA SuperNova 1300W | Case: Fractal Define R4 | Monitor: X-Star DP2710 1440p @ 96Hz | Mouse: DeathAdder  | Keyboard: CM Storm CherryMX Red | Headset: Kraken Pro | Headphones: HE-400
https://linustechtips.com/topic/101964-384-vs-512-bit/#findComment-1363749
thats not what the bus is for
facepalm*
we are passed the days where 1mhz from one processor does not equal 1mhz from a different one from a different archetecture
https://linustechtips.com/topic/101964-384-vs-512-bit/#findComment-1363765
facepalm*
With Vram it does make quite a difference though. There isn't much difference in ram overall.
Maybe not enough for 1Ghz to equal out to a 512bit bus, but it's a nice boost either way
https://linustechtips.com/topic/101964-384-vs-512-bit/#findComment-1363815
yes, but... this improvements are much more noteables on the low/mid/high range cards
where you can clearly see the difference of power between
low - 64 bits
med - 128 bits
high - 256 bits (this is the old high end standard)
S high - 384 bits (this is the actual high end standard)
U high - 512 bits (this is the future high end standard)
APU = A10
https://linustechtips.com/topic/101964-384-vs-512-bit/#findComment-1364360
facepalm*
Um, if we are talking about raw bandwidth, then the architecture doesnt matter at all.
A 512-bit bus running at 5 ghz effective has a 320 GB/s Bandwidth, a 384-bit bus running at 6 ghz effective has a 288.4 GB/s bandwidth.
Architecutre doesnt matter when we are talking about raw bandwidth...
https://linustechtips.com/topic/101964-384-vs-512-bit/#findComment-1364738
