SO im planning to build cheap workstation and low gaming pc.
my plan its to used Ryzen 2200g APU for gaming. and add 16GB 3000mhz ram to boost rendering
but...
i have laptop currently running with i5 , mx150 25 watt and 8 gigs of ram
its the pc build stronger than my laptop? or should i just spent 100$ to add 8gb more to laptop
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
https://linustechtips.com/topic/1012020-pc-for-rendering-1080p/
10 minutes ago, SidM said:
which i5 may i ask?
8250 U. ultrabook
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
https://linustechtips.com/topic/1012020-pc-for-rendering-1080p/#findComment-12112986
