Display resolution mismatch? Help!
Go to solution Solved by AbydosOne,
14 minutes ago, handymanshandle said:
Really, any normal GPU should fix it
I'm going to argue against a new GPU and say get a different monitor, all things being equal, even just to check if it will work. (Cheap 1080p HDMI monitors aren't hard to come by (at least in the US).)
If the monitor won't display UEFI using on-board graphics, there's nothing saying it will work with a different GPU (especially if they're both AMD).
Okay so im building a web surfing pc with aorus pro gaming b450 wifi mobo, ryzen 5 2400g, 8x2 gb of ddr4 corsair vengance @ 2400mhz, and whenever i went to bench test it i get "resolution mismatch" "change device resolution" but it did display bios for like 1/2 a second? What are my next steps how can one possibly change display settings without a display?
https://linustechtips.com/topic/1007078-display-resolution-mismatch-help/
What is the model of display you're using? How are you connecting to it (DVI, HDMI, DP, VGA)?
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
What monitor do you have?
Because from what I remember, certain monitors really don't like the way the Ryzen APUs output video in the UEFI menus.
Its an old flatscreen using hdmi. Not ideal, but my monitor only has vga and my mobo doesnt. Its insignia or element i think. No drivers or anything as i cant get anything to display
The TV may just hate the output it's giving. Usually TVs (and monitors, of course) that can accept strange refresh rates and strange resolutions have better luck with PCs.
I looked up your motherboard and it doesn't support DVI-I -> Dsub, so that's out.
What is the exact model of monitor (or its native resolution if you happen to know it)?
My guess is that the monitor is something odd (like 1440×900 or 1680×1050) and the scaler inside doesn't know what to do with input that is not within a small range of acceptable resolutions (and I'm guessing UEFI resolution is 1920×1080).
Network:
1 minute ago, DawsonWood said:
So basically i need to get a new monitor ? Would something like a saphire 580 fix it?
Really, any normal GPU should fix it, so long as the TV you're dealing with can read an output of, something like 1024x768, likely what your UEFI on the board will default to.
Network:
Just read this now after ordering a 580 lol Yay me. Ill probably just finish the build and bring it to a friends to switch between monitors and find a resolution that works with my tv
