Hello again :)
So i didnt think my new Computer Setup really fully threw, which means that my Cables wont reach the Computer because it is to far away :/
I would need arround 1m 50cm / 5 ft...
And will it work? Or will i lag ._.
Thx and have a nice start in your week ;)
https://linustechtips.com/topic/1003097-usb-extension-hub/
Just now, sterixir said:
Could it work with like only a USB 3.0 Extension Cable and then have a Hub at the end? (just as an idee)
It could work, but as @timl132 said you might run into power problems with it, and perhaps a bit of lag
https://linustechtips.com/topic/1003097-usb-extension-hub/#findComment-12033182
Just now, mrfluffy96 said:
if we have seen linus run a GPU from 3m away, so it can be done but my advice dont cheap out on the cable cheap cables tend to be bad. but if this is for USB then it should be ok if your just planing to run a mouse and keyboard on it.
? hope this helps
Yeah, but those were expensive sleeved extenders on a way faster interface
https://linustechtips.com/topic/1003097-usb-extension-hub/#findComment-12033185
That's practically not possible for things to lag, USB is made to avoid things like that.
1 minute ago, sterixir said:
Well it would be my Headphones, Mouse and Keyboard...
Should be fine.
https://linustechtips.com/topic/1003097-usb-extension-hub/#findComment-12033190
I really dont want lag :/ so lets put the HUB idea away for 1 sec, would it work better with 3 Extension Cables?
https://linustechtips.com/topic/1003097-usb-extension-hub/#findComment-12033195
Should be fine.
Theoraticly not, but I had some real problems with a 5 meter one, so I just warned that the possibility exists
https://linustechtips.com/topic/1003097-usb-extension-hub/#findComment-12033197
1 minute ago, timl132 said:
Yes, your devices don't require a super high speed connection, so why bother with 3 cables. And with a hub you get the option to plug-in a USB drive or something.
I just thought 3 Cables would maybe work better (because of the whole lag thingy)
https://linustechtips.com/topic/1003097-usb-extension-hub/#findComment-12033204
Next Question would be what kind of USB Hub ._. should i just look out for a 3.0 USB hub?
If posible, yes. But if your ectension cable or PC doesn't suport it, then no. I'd grab a USB 3 hub if possible, so you don't run in bandwith issues' if there might be any.
https://linustechtips.com/topic/1003097-usb-extension-hub/#findComment-12033209
I (will) have a Aorus Z390 Pro Wifi with 3.0 USB's so that wont be the problem, but i just had a look on the internet and i coundt find any Hubs with like 5ft (or 1m50cm)
https://linustechtips.com/topic/1003097-usb-extension-hub/#findComment-12033220
Just buy an USB 3 extension cable, they are quite cheap. And attach your hub to that.
https://linustechtips.com/topic/1003097-usb-extension-hub/#findComment-12033228
