  • entry
    1
  • comments
    3
  • views
    765
Why there should be AIO Phase Change Systems
ZexenPro
Phase Change is really cool. The people with these systems can say "yeah, my computer is basically a refrigerator". The problem is, these systems are so complicated, us poor people have no way to build one. AIO Phase change would be relatively easy. It wouldn't be as easy as installing an h100iGT, but thats fine. the insulation stuff would be included, but you'd have to put it on. It would be as hard as flexible custom watercooling. Everybody help me out and campaign for AIO Phase Change.
3 Comments
Step 1. Buy a Phase Changer and other supplies
Step 2. Insulate Socket
It being an AiO wouldn't make it any cheaper than the parts would be normally, infact it would probably raise the price...
