First build (voltage hypersonic) gaming PC gaming pc first build companys first Entry posted by Voltage_CEO_01 September 29, 2015 702 views Share More sharing options... Followers 1 This system is designed to be fast. The prosseccer, the ram, and the SSD contribute to this. http://pcpartpicker.com/user/Voltage_CEO_01/saved/mv6frHt
Guest · Guest Posted September 30, 2015 can u write the specs. the link isnt working Link to comment Link to post
Voltage_CEO_01 2 Posted October 23, 2015 http://pcpartpicker.com/user/Voltage_CEO_01/saved/mv6frH New link Link to comment Link to post
Guest · Guest Posted October 26, 2015 Why so much on case? Your motherboard doesn't even need something of the size, and If you spent a little less on something like a bitfenix prodigy, you could get a 6700K and a compatible motherboard that still supports your RAM. Here are some links: http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=9195044&SRCCODE=WEBGOOPA&scid=scplp1889872&gclid=CMWErrKN38gCFUdlfgodXWQMiA http://www.provantage.com/asus-h170-plus-d3~7ASUS2QK.htm?source=googleps&gclid=CLfNjOKO38gCFYRDaQod7oQIlA http://www.newegg.com/Product/Product.aspx?Item=N82E16819117559 Link to comment Link to post
Voltage_CEO_01 2 Posted October 29, 2015 Thanks for the advice, but it looks really cool. Link to comment Link to post
Voltage_CEO_01 2 Posted October 29, 2015 And I wanted to go with a white,black,grey,blue scheme. That's not a good color Link to comment Link to post
5 Comments
