  • entry
    1
  • comments
    3
  • views
    1,099
first gaming pc build
hi I'm building my first gaming PC and I'm not sure which parts I have to choose. I have a budget of 2200
I would like to play with good fps and good image quality.
I will be playing games like battelfild, coll of duty, fallout 4 and metal gear solid 5
I have made two proposals but will be very happy if you guys will lok at it to see which is best and if i should pick som oder parts.
http://pcpartpicker.com/p/dJpNhM
http://pcpartpicker.com/p/yJgpwP
thank for your help.
3 Comments
Ethers
Posted
Yeah I agree you should go for the gtx 980ti you will get a lot better perfotmence from it.And if you can get the skylake i7-6700k cpu and ddr4 RAM it should't cost much more :)
frederik_ok
Posted
Thank you , but if I have to have the CPU and DDR4 RAM should I not have another motherboard than the z97 -a. and if should i replace som oder parts for the built to work?
