  • entry
    1
  • comments
  • views
    900
I need help
xStylezZz
Ive struggled with my internet for ages, i live in the netherlands and my internet speed is around the 50-100 Mbps.
Everytime we buy a new Router it works well for a month, but after that the bad connection comes back.
I want your guys advice, what is a good router, and how do i easilly improve the connection.
My walls and floors are quite thick... I need a router that is good enough for my whole house.
At the moment my provider is Ziggo. I dont know if you guys know it, but if you do, can you tell me if its good, or should i switch?
Thanks a lot!
Wouter
0 Comments
Guest
This blog entry is now closed to further comments.
