Power Supply
  • entries
    5
  • comments
    13
  • views
    1,434
HELP Power supply
Hello,I have a corsair cx 750w power supply and since I bought it every time I hit it lightly my PC restarts .I think it might have fixed its self but I don't wont to try.And when I start playing a game it makes strange high pitch noises. I would like to by a new one so my question is will a 600w super flower PSU be enough for my RIG:
cpu:Intel core I7-3770 ivy bridge 3.4GHZ
gpu:asus strix nvidia gtx 970
MB: asrock h77m LGA 1155
2x4gb RAM 1600
1xHDD western digital blue 1tb 7200
1xHDD seagate 500gb 5400
1xssd kingston 120gb
CPU cooler : thermaltake frio silent 12 (the one fan model)
Thank you for your time :)
6 Comments
ENJ
Posted
Well my AMD power-siphon uses about 525w under full load and I have a TX-650w. So I'm 99% positive a 600-650 watt PSU would be just fine for your rig :)
thereelablegnome
Posted
Yeah agreed. 600w would be plenty because i've seen people running gtx 980s with the same amount of power.
Ethers
Posted
That sounds like coil whine to me... Go to http://www.coolermaster.outervision.com/ to check about how much power your system will need. Remember that it is nt 100% accurate so you will need to get a bigger wattage PSU then it recommends :)
I have done that it says 344w but I don't think a 400w power
supply will be enough :)
