Finally Some Results!:
Geil VRM sinks came this morning, only two days late... Anyway, these sinks are pretty small and with a fan ghetted on the card pretty poorly, they still hit 103 degrees with furmark. However, in regular gaming, I am seeing 95s on average which is on par to the reference cooler that was on here. This post isn't about the core temps but I'm really happy with them. So this higher VRM temp is worth the sacrifice.
Can I Make It Better?:
I can certanly get rid of the thermal pads that came with the VRM sinks, replaceing it with a nice dolop of MX-4. Which could help with the temeratures. Moreover, placing a fan closer to the sinks will be much better. The original schems for the drawer build had me using the flow directly from the rads to cool the MOSFET, VRAM, RAM and VRMs but I think I am looking at adding more smaller fans into the mix. I suppose the two 200mm NZXTs I have hanging arround would suffice but they would wreck my airflow. Since this is by no means the finnished design I will not be posting in depth test results.
Photos!:
Whats Next?:
Tomorrow moring I will be uploading some core temp readings and tomorrow evening there will be proper bench results. Using furmark and Vally most likely. In addition, I have H60 CPU temps to post on the drawer blog. As well as some mounting test images and other odds and sods. I'd apologise for the lack of content over the past few days but it's not like I've been slacking off. My main systems motherboard died, GA-990FX-UD5. Flat out broke, PC shut down mid youtube video and would not post. So I'm suing an MATX GA-78LMT-USB3 I theived out of my sisters build. Some good news though? I am going to be splurging and grabbing an Asus Formula V. So look forward to that blog.
Thank You :)
2 Comments
