Case survey 14/07/2014
Case survey
2 members have voted
1. How much would you be willing spend on a case? (think hypothetically and realistically.)
between $0 - $500
up to $100 tops0
between $100 - $2001
something luxurious $250+1
2. Where do you see the sweet spot size for a case? (pick a size, choose a flavour.)
full tower1
mid tower1
mini tower0
full atx2
micro atx0
mini itx0
3. Which features attract your attention? (try to narrow your choices down between 2-3.)
portability | i.e under 30lbs/15Kg0
ease of use | i.e cable management0
customizability | i.e removeable hard drive mounts1
pure aesthetics | i.e solid colour with laser LED glowing affect0
something unique | i.e made of oakwood0
build quality | i.e constructed using metal1
well rounded feature set0
air/Water cooling optimized2
4. How can a computer case lose your fascination?
Price doesn't fit the product0
Lack of understanding the enthusiast's requirements0
Over-hyped marketing1
Unfunctionable2
Looks attrocious0
5. Who is your preferred case manufacturer?
antec0
asus0
bitfenix0
corsair0
cooler master1
cougar0
fractal design0
in win0
lian li0
phantek0
nzxt0
shuttle0
silverstone1
thermaltake0
xigmatek0
zalman0
other0
So if you may or may not know of whether you read blogs, I'm currently now designing two upcoming cases which'll probably be built & released around next year 2015 during mid-summer or the autumn period. The first case will not be for sale but if I feel that there is a audience that deems worthy I may put it into to-order batch produce, the second case will be purchasable from my upcoming website to order/pre-order if I can produce enough stock & based on a lot more of key manufacturing elements.
I have produce a simple poll which I'd like the community to answer, you can also write out and justify your reason if necessary (which will be helpful in-terms of feedback for me.) If you want to know more about what I'll be doing follow me on my blog not twitter.
I think my last question is; what case are you currently using and why? asas
0 Comments
