  • entries
    56
  • comments
    5
  • views
    4,574
TEJI Designs. Project Silverstream
TEJI Designs™ Kingsley Wong. - Custom case designer & builder
side Project Silverstream/line (name to be confirmed on a later date.)
This case unlike the M13 will feature specifically for the mini/micro & full size atx spec. Mid tower atx and below, price point TBC on a later date with it being focused on luxury showcase chassis. The entire case construction & structure consisting of aluminium & steel. No plastic option(s) but if needed I will use a very limited amount.
Full tinted glass window which has a curve & subdued aesthetic across the center, at the end of the material it's curved close enough to a 90 degree angle. Top and bottom of the glass has aluminium folded around to protect and attach the window side panel to the main chamber itself; rubber for vibration dampening & magnetic pieces to secure panel to close extremely tightly but making a connection. (The weight might cause issues due to the materials composite and dimensions) Ensure that the outside will also include rubber mounts.
GPUs will also have the 50-85 degree rotation like Project M13.
Hidden HDDs bay. Power supply mounted portrait but has a compatible interchangeable plate to mount landscape.
Include a nice looking dual 5.25" power button, reset, usb 2.0/3.0 etc. Must fit on the side or top.
Custom paint job; space themed; of the universe/galaxy
I have planned out to fit these components within the case unless I change the option to do so on a later date.
Hardware list']
CPU - Using either Broadwell/Skylake [Mainstream microprocessor architecture]
Motherboard - Asus Maximus 7 Formula or MSI Gaming 9 AC [Painting white, custom metal/plastic shroud]
RAM - Corsair Dominator Platinums/Kingston Fury 16GB/32GB
GPU - GTX 780 or 780 ti stock reference cooler, if not I would use a stock R9 290 with a waterblock then put on the original shroud + sprayed arctic white with gloss.
SSDs - Something from A-DATA/Corsair/ Intel (730 series) /Kingston/Plextor
HDDs - 4/3TB HDDs in Raid 1/5/6
Power supply - 750-1000w
Criteria 24+ pin power, dual eps 8+ pin cpu power, 4/6x 6+2 pin pci-e power, 3/6 Sata peripheral cables
scratch the hardware list.
0 Comments
