Bash history script , that collects all , and sync all with current on top:
#!/usr/bin/env bash # ############################################################################ # # PATH: /opt/local/config/rc/bash AUTHOR: Hoefkens.j@gmail.com # # FILE: 311_history.conf 2023-04-04 09:33:40 # ############################################################################ # HISTFOLDER="/var/cache/bash/history" HISTGLOBAL="${HISTFOLDER}/history.glob" HISTSESSION="${HISTFOLDER}/history.session.$$" HISTFILE="${HISTFOLDER}/history.$$" HISTSESSIONS="${HISTFOLDER}/history.[0-9]*" HISTSIZE=-1 ; HISTFILESIZE="$HISTSIZE" ; HISTCONTROL='' function _orphants { # detect leftover files from crashed sessions and merge them back local _active _pattern _orphaned _active=$(pgrep `ps -p $$ -o comm=`) _pattern=`for pid in $_active; do echo -n "-e \.${pid}\$ "; done` _orphaned=`ls $HISTSESSIONS 2>/dev/null | grep -v $_pattern` function _merge { echo Merging orphaned history files: for f in $_orphaned; do echo " `basename $f`" cat $f >> $HISTGLOBAL \rm $f done } function _remove { for f in $_orphaned; do gio trash $f 2>/dev/null || rm -fv $f done } [[ -n "$1" ]] && "$1" unset _merge _remove } function _bash_history { builtin history -a "$HISTFILE" builtin history -a "$HISTGLOBAL" builtin history -c #env cat "$HISTGLOBAL" > "$HISTFILE" #env cat "$HISTSESSION" >> "$HISTFILE" builtin history -r "$HISTGLOBAL" builtin history -r "$HISTFILE" } function history_merge { _orphants _merge } function history { _bash_history builtin history "$@" } [[ "${PROMPT_COMMAND}" != *"_bash_history"* ]] && export PROMPT_COMMAND="_bash_history ; ${PROMPT_COMMAND}"
0 Comments
