Bash Aliasses (update:changed gio trash to trash-cli)
Some of you might have notice that when you run gio trash inside a bind-mounted folder, it fails with:
theirs seems no fix for this in term s of gio trash, however , trash-cli has no problem doing this, its not as versatile as gio, (only does trashing|restoring|cleaning) but it does trashing really well,
so i changed the aliasses in my bashrc alias file to this command. Here is the updated version of the file:
#!/usr/bin/env bash # ############################################################################ # # PATH: /opt/local/config/rc/bash AUTHOR: Hoefkens.j@gmail.com # # FILE: 501_aliases.conf # ############################################################################ # # ReSource Bash Running Config (use after config changes) alias rebash='source ~/.bash_profile' # ls & exa Shorhands alias ll='ls -bghAls' alias llr='ls -bRghAls' alias trex='exa -T' alias llt='exa -laT' alias lltl='exa -laTL' # rm alias del="rm -rv" alias delf="rm -rvf" # trash-cli | ~~Gio Trash~~ alias rm='trash-put -vf -- ' alias rmu='trash-restore -v' alias rm-list='trash-list' alias lsrm='trash-list -v' alias lstrash='trash-list -v' alias rm-clean='trash-empty -v' alias rmrm='trash-empty -cd v' # Cpu Control alias frqmax='cpupower frequency-set -g performance' alias frqmin='cpupower frequency-set -g powersave' alias frqinf='cpupower frequency-info' # cp copy & mv move & rename & mkdir alias cp="cp -vR" alias copy="gio copy --preserve -bp" alias mv='mv -v' alias rename='gio rename' alias mkdirs="mkdir -vp" # disk space alias df='df -h' # human-readable sizes alias free='free -m' # show sizes in MB alias duKB='du -hcsxBk' alias duMB='du -hcsxBm' alias duGB='du -hcsxBg' alias du-s='du -hcs' # btrfs alias btr-du='btrfs file du --human-readable -s' alias btr-f='btrfs file' #= btrfs filesystem $ # btrfs subvolume alias bs-='btrfs subv' #= btrfs subvolume $ alias bs-ls='btrfs subv list' #= btrfs subvolume list $ alias bs-dd='btrfs subv snapshot' #= btrfs subvolume duplicate $ alias bs-mk='btrfs subv create' #= btrfs subvolume create $ alias bs-rm='btrfs subv delete' #= btrfs subvolume delete $ #systemctl alias sctl="systemctl" alias uctl="systemctl --user" #ps alias psa="ps auxf" alias ppsgrep="ps aux | grep -v grep | grep -i -e VSZ -e" alias bat="bat --plain --pager=never --color=always"
0 Comments
