  • entry
    1
  • comment
    1
  • views
    765
what is the best gpu closed water cooling?
khaled adel
my computer spec:
i7-8700k
16gb 2666mhz
msi gtx 1070 gaming x oc
msi z370 gaming plus
my case raidmax segma its support 2 water cooling system 240mm in up and 360mm in front
i already buy nzxt krarken x72 for the cpu and put it in the front
now i was confuse about my gou which type or brand should i buy to make it best cooling
note: im an architecture and gaming but i buy this pc for my work so i work a lot at the gpu for rendering for hours so that why i confused in buying a water cooler for it
1 Comment
