  • entries
    5
  • comments
    3
  • views
    5,003
Planning 750D watercooling.
So I have been using my Corsair 750D with just a Swiftech H320 CPU watercooler for a while now but I bought the 750D with custom watercooling in mind so I think it is time to start planning what I will be doing.
Mods: As of now, the only real mod I plan on doing is removing the 5.25" bay. Once that is gone I want to get a custom metal plate for the front and transform the entire front into a triple 120mm radiator (140mm if it fits.)
Things to buy: One, maybe two GPU blocks, CPU block, massive res, pump, still deciding whether I will do hardline or soft tubing but leaning toward hardline and 2 360 rads, and some steady hands. I probably forgot some possibly critical things but oh well.
Hopefully I will do this over Christmas Break this year (2014)
0 Comments
