  • entries
    63
  • comments
    50
  • views
    22,043
Let's build the PS4 Pro
EDIT: It's probably a good idea to lay out some ground rules at the top so people know how I'm approaching this:
  1. Everything must be new. The reason being the used market is not consistent or reliable.
  2. Everything must be gotten from official channels.
  3. Hardware must be matched as closely as possible. If the exact part or equivalent cannot be found, a justification must be needed.
  4. If a part on the PS4 is available for the PC, it must be included.
    1. If I'm allowed to leave out some parts though, its price must be reflected against the console. So if I omit a $40 part, I must subtract $40 from the PS4's price.
    2. Certain things that are not known like the secondary ARM chip and its DRAM, can be left out for the sake of argument.
Every once in a while I like to see if I can build a machine that closely matches the PS4's specs as much as possible and see how much it would cost. I've done the PS4 a few times, so let's do the PS4 Pro:
PCPartPicker part list: https://pcpartpicker.com/list/g9L6pb
Price breakdown by merchant: https://pcpartpicker.com/list/g9L6pb/by_merchant/
CPU: AMD Athlon X4 880K 4.0GHz Quad-Core Processor  ($92.34 @ Newegg Marketplace)
Motherboard: ASRock FM2A68M-DG3+ Micro ATX FM2+ Motherboard  ($44.99 @ SuperBiiz)
Memory: Crucial 4GB (1 x 4GB) DDR3-1600 Memory  ($24.88 @ OutletPC)
Storage: Toshiba 1TB 2.5" 5400RPM Internal Hard Drive  ($54.89 @ SuperBiiz)
Video Card: Gigabyte Radeon RX 480 4GB G1 Gaming Video Card  ($189.99 @ Newegg)
Case: Rosewill RANGER-M MicroATX Mini Tower Case  ($24.99 @ Newegg)
Power Supply: SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply  ($49.99 @ Newegg)
Optical Drive: LG WH14NS40 Blu-Ray/DVD/CD Writer  ($46.88 @ OutletPC)
Total: $528.95
Generated by PCPartPicker 2016-12-09 13:02 EST-0500
Most of the parts were the cheapest parts I could source that at least wouldn't blow up in my face (hence the SeaSonic PSU). But let's go over the key points here:
  • Processor: The PS4 Pro has a 2.1GHz 8-core Jaguar. In this I included a quad-core Athlon X4 running at 4.0GHz. The assumption is that doubling the speed but halving the cores will result in similar performance. Also the Athlon X4 uses the Steamroller architecture, which should be a bit better than Jaguar's
  • GPU: The PS4 Pro has something that resembles a downclocked RX 480 (911MHz vs 1120 MHz). So I went with the 4GB version of the RX 480 mostly because from the only resource about GPU memory consumption I could find on the PS4, graphics consumes about 3.5GB.
  • Memory: 4GB for the GPU leaves 4GB for the system to keep it "fair". That same resource also suggested that 3 GB or so was used for the system outside of the game.
  • Storage: The PS4 Pro comes with a 1TB 5400RPM 2.5" drive, and probably a cheap one too.
  • Optical drive: Because the PS4 Pro has one and I need to keep this fair. But it is the cheapest one PCPP had listed.
Hm... Even without an OS or peripherals I'm still about $130 over and there's not a whole lot I could cut off.
EDIT: As of 01/04/2017, the price jumped up another $36 for the parts, to a total of about $566
CPU: AMD Athlon X4 880K 4.0GHz Quad-Core Processor  ($92.29 @ SuperBiiz)
Memory: Crucial 4GB (1 x 4GB) DDR3-1600 Memory  ($23.48 @ Amazon)
Video Card: Gigabyte Radeon RX 480 4GB G1 Gaming Video Card  ($224.98 @ Newegg)
Case: Rosewill RANGER-M MicroATX Mini Tower Case  ($33.30 @ Jet)
Power Supply: SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply  ($44.98 @ Newegg)
Total: $565.79
Generated by PCPartPicker 2017-01-04 19:11 EST-0500
3 Comments
Guest
· Guest
Posted
Not bad. I wish blog was more accesible or more visible to people
AlTech
Posted
@M.Yurizaki Hate to burst your bubble but PS4 Pro has 8GB RAM. And the equivalent of 2x AMD Athon 5350s for CPUs...............
Mira Yurizaki
Posted
8GB of shared RAM, and the only slides I can find from developers who showed the memory usage (look up Killzone Shadow Fall Post Mortem) posit that the main system takes 3GB for itself, leaving 5GB total for the games. 3.5GB of that was used for the GPU and the rest for the game itself.
As far as I know, the PS4 Pro did not increase the memory capacity. However it can render 4K using a tiled approach which requires less bandwidth.
Also as far as I know, the CPU is still a Jaguar CPU, just with a clock speed bump. Jaguar is a netbook class architecture. So a desktop class architecture should be more than enough to make up for any deficiencies that simply doubling the clock speed but halving the cores might do. Also, you can't buy dual socketed AM1 boards
