Lerodz8
  • entry
    1
  • comments
    5
  • views
    1,405
Help whit upgrading my pc!
Can my system upgrade to a gtx 950 it has a : >AMD FX-4300 3.8GHz
>8GB DDR3 1600
>AMD Radeon HD 7670 2GB GDDR3
>a 350w power supply
>Chipset AMD 970
>http://www.newegg.com/Product/Product.aspx?Item=9SIA24G1XA5604&cm_re=cm1855-_-9SIA24G1XA5604-_-Product (link to my pc incase of any question's)
5 Comments
Whackapuss
Posted
It should be fine. Just make sure that you have 6-pin power connector on your power supply. The power supply IS big enough just make sure it has one of these cables:
asdffdsa
Posted
You can build bettter machine for that amount of money.
CPU : FX8300
GPU : Radeon HD7770(bought it second hand)
RAM : 16GB (HyperX 1600MHz)
Motherboard : Asus M5A97 R2.0
PSU : 500W
SSD : Kingston 240GB 450MB/s read and write
CASE : MS Maverick
Made this PC myself for less than 450$.
mlalcevski
Posted
You can upgrade with no problems, just dont try to overclock it you wont gain much but you will get into stability isues real fast with gpu.
MaxBeast4Z
Posted
CPU : FX8300
PSU : 500W
CASE : MS Maverick
for $450 it's not bad the specs are decent for the price you pay
