  • entry
    1
  • comments
    6
  • views
    1,291
Hi Need Help Picking checking part compatability
Hi this is the first time making a computer. I'm looking to make a decent gaming computer but I'm not sure if I'm using the appropriate parts
My price range is around $600-800; price is the highest priority. My uses include web browsing, watching shows, and light gaming
http://pcpartpicker.com/p/sRHb7P
This is what I have so far . Please comment your suggestions
6 Comments
Jack-D
Posted
use a ATX motherboard and look at getting a gtx 760 or 960 instead of a 750ti
Lordmac14
Posted
Looks good, but ATX mobo + too high wattage a PSU even if planning to upgrade + if you can get something like a gtx 950/960
SlyDeath222
Posted
I agree with what has already been said. A full ATX motherboard adds room for expansion and a higher end GFX card allows for better performance in more games. A 750 watt PSU is a bit overkill, but I can't tell you that(I'm using a 1200 watt PSU for a pc that draws 400).
CrapShackGaming
Posted
i would go amd because it a lot cheaper and get a lower watt psu
N9UDT
Posted
Take a look at the ASRock H97 Anniversary ATX for the Motherboard and the EVGA GeForce GTX 960 2GB for the GPU. It's just a thought.
