i Have a problem.. :3 Entry posted by AnestisManiaaa October 12, 2015 636 views Share More sharing options... Followers 1 every time i go into my game its like this can some one help :3,. its like this for all my games why my resolution is like this :/.
Tech_Dreamer 32,525 Posted October 13, 2015 reset monitor to factory settings or driver issues, but taken that it's an ultrawide monitor i think it's trying to fit into the skewed ratio & you're kinda trapped Link to comment Link to post
Voltage_CEO_01 2 Posted November 1, 2015 Do you have all your drivers. If not install the video drivers or fix them. If that doesn't work go into your monitor settings and change the screen format. If that doesn't work reset it. If that doesn't work then your screen is probably not compatible. Link to comment Link to post
2 Comments
