  • entry
    1
  • comments
  • views
    746
Avermedia LGP firmware/blue ring of death
Frosteler
Hi, I just recently bought myself the Live Gamer Portable and everything seemed to be working fine right out of the box until it came to downloading and updating the firmware. My RECentral Does not seem to be able to detect my device at all and the blue light on my Live Gamer Portable continuously flashes in circles. When I switch the mode on the device to the right (PC Free Mode) it seems to work perfectly fine with the red light only flashing for a couple of seconds and then turning solid but I am not able to record anything due to the RECentral not being able to detect my device. Every time I try to un install the firmware and re download it, my computer successfully downloads everything without any problems and my computer recognises the device but installing the firmware I always end up getting the same message of "Device not detected. Please make sure the Live Gamer Portable is switched to PC mode and is connected to the PC".
Someone please help if you have experienced this problem and have found a way to fix it!
0 Comments
