  • entry
    1
  • comments
    4
  • views
    869
Reccomendations for watercoolong
Leongwd
Hi there, I'm planning to watercool my PC which consists of a i7 5930K and a GTX 980 Ti. My computer case is a Phanteks Enthoo Primo, I was wondering which rads, pump, tubing and waterblocks I should get to watercool it.
4 Comments
Erm buy the thermaltake water 3.0 ultimate
Ah yes I agree I water cooled my old custom build with that.
Do it from scratch. The universe will be a worse place if you put an AIO watercooler in an Enthoo Primo. Use the mounting spot in the back for a tube reservoir. I'd maybe use a reservoir and a rig for it that can hold a Swiftech MCP35X too. Or go with a huge pump like the Laing D5 with a flashy top and/or a noise-reduction box. Rads at top and front. Hard tubing if you're up for it. Some digital controller for the fans. The door in the front can't handle knobs very well. I'd go with all EKWB especially if you're from EU.
Right, any brand of rads will be fine won't it
