  • entry
    1
  • comments
    12
  • views
    1,055
HELP
GoingxBig
I have no where else to go i have a asus x55lb laptop
SPECS:
i5-5200u 2.2Ghz
940m 2gb
8GB ram
windows 8.1
when ever i on just on browseing the web for around an hour i crash or i play like ARK SURVIVAL EVOLVE or DAYZ STANDALONE for around 10 mins than i crash my GPU temp gets up to around 78-84C i tried putting a fan on it but nothing happens some times it comes up with the blue screen of death and it says WHEA_UNCORRECTABLE_ERROR. than other times i crash and nothing comes up. ive factory reset the laptop and ive dont almost everything how do i fix it plz!! much appreciated
12 Comments
GoingxBig
Posted
The highest it got up to was 84c but it will play for a while than it will crash some times I'll be in the 70s and it will still crash
GoingxBig
Posted
The longest I played on the laptop without a crab of constant gameplay was like 5hours
KilimanjaroGaming
Posted
Well it's obvious it is over heating, I had the same problem with my PC and all I did was just clean all the dust inside. I would recommend you to give it to someone to check maybe something else is wrong with it.
MaxBeast4Z
Posted
Is the fan running.
Was the laptop ever overclock.
Did you ever bought this laptop new or did you bought it used.
GoingxBig
Posted
KillimanjaroGaming-ive cleaned it out it was barely dusty but i did give to to my friend and starter to look at it and he found that one of my devices were corrupted. and when i went to update it. it said that it was already updated an but it has the yellow caution help and its new
MaxBeast4Z
Posted
that's not normal do you got support on that laptop
Roger Mallory
Posted
The only things i can recomend doing is reinstalling the games or software that crashes and getting better thermal paste inside your laptop.
Keven_Z
Posted
WHEA_UNCORRECTABLE_ERROR is an error message for either if there is a system hardware failure or the Windows driver failure, it may be because of the communication between the Driver that Windows was installed in they are not responding, or RAM, HDD, anywhere where your system could not respond to. Here are some instructions from the Web
  1. Reboot or close the Windows 8.1 PC
  2. When the PC starts press “F8” on the keyboard or another combination would be “Shift + F8”.
  3. The “Recovery Mode” should start.
  4. From within the “Recovery Mode” you need to select “Safe Mode” by following the instructions on the screen.
  5. After the Computer boots up in “Safe Mode”, hover the mouse to the right side of the screen and click in the search box in the start menu.
  6. Type in the search box “Device Manager”
  7. After “Device Manager” is opened we need to update the drivers one by one. This way we will see if one of our drivers has caused this error to appear.
  8. After updating the drivers we need to reboot the PC.
  9. See if you get the same error message.
