I need a 1080p gaming monitor 200$ or less please help Entry posted by noor May 26, 2015 460 views Share More sharing options... Followers 1 HI i need a gaming monitor please leave suggestion in the comments and thanks
Diamante1185 1 Posted May 27, 2015 Asus's VX228H seems to be a great option. I've found that 21.5 inches on a 1080p monitor is pretty great, however if you want to get a little larger (23 is my personal sweet spot for 1080p) BenQ's GL2460HM has solid reviews provided you're fine with less than excellent viewing angles. If you want to get a better screen, closer to $200, then I would probably recommend the ASUS VX238H. It seems to have amazing reviews if you're fine with a little thicker bezel. These are just some options, be sure to look around a little more because there could DEFINITELY be better options for you. If I was in the market, I would probably go with the BenQ one because I like three monitors and I would like the thinner bezels. Make sure you read the reviews as well so you know exactly what you'll be unboxing. VX228H: http://www.newegg.com/Product/Product.aspx?Item=N82E16824236358 http://www.bestbuy.com/site/asus-21-5-led-hd-monitor-black/5818083.p?id=1219159698849&ref=199&loc=8BacdVP0GFs&acampID=1&siteID=8BacdVP0GFs-GVCkR9Dyter_hvCVDfXd2w GL2460HM: http://www.amazon.com/BenQ-GL2460HM-24-Inch-LED-Lit-Monitor/dp/B00IKDFL4O/ref=cm_cr_pr_product_top?ie=UTF8 VX238H: http://www.newegg.com/Product/Product.aspx?Item=N82E16824236305&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID= Link to comment Link to post
Diamante1185 1 Posted May 31, 2015 Found this today and I'm actually thinking about upgrading to it http://www.amazon.com/Asus-VS248H-P-24-Inch-Full-HD-LED-lit/dp/B0058UUR6E/ref=pd_bxgy_147_img_y Link to comment Link to post
2 Comments
