In-progress refinement of my Project M13
TEJI Designs™ Kingsley Wong. - Custom case designer & builder.
I would hope to say and guess that this second update will be a bit more refine the the first which there happens to be a link of my first Blog above
So what is Project M13 you may ask? It is a custom fully build pc for myself Kingsley Hopefully by the time I have covered all the necessary design improvement flaws and development I can proceed towards the daunting task of purchasing materials & equipment in due time
Harnessing the knowledge necessary for me to become a tiny bit awesome.
So what I had begun to do last time which was about two months ago was draw up a sorta brainstorm of the mandatory things I would have liked to be in my design
I am still disputing whether I should make a couple more incremental adjustments (by which I probably do need to revise over getting myself and other members of maybe this community or friends to place feedback on)
I have two very swell good ideas for a future design studio of some sort called TEJI Design and M13 which is a slight deduction for my other logo or branding of my first original name before teji designs called magnitude (thirteen) iota (nine) bear with it ~_~ I cannot type with my numbers since my keyboard on this laptop is broken
Furthermore I might plan to change my laptop to another one with a beefier graphics card ram etc but back to my original point I am probably in need of wisdom and knowledge so I am conjuring whether I should not only keep my list of mandatory drafted spec list or make an entirely new one
I will probably keep it since writing a new one isnt hard but might not live to my expectations anyway but I will be either putting another system within the case or chassis which will be a whole new challenge to compete with having already wanting a entire Haswell E system inside adding either now an MATX system OR an MITX build too
If more cores and low power is possible by the time haswell E revision twenty eleven three point zero and the newer broadwell with maybe six cores vs quad core ugh (u_u)
Designing is sorta going well but I have not drawn anything due to my brain refusing to leak any of its ideas in the imperial courtroom of Kingsley"s >_<
Back to where I am currently making incremental shifts in motion
The motherboard will feature an all aluminium design using a clear transparent or translucent single piece of acrylic to make a glowing effect for aesthetical purpose
It might actually be a four piece since I had originally be a single piece which would be reversible due to rotary switches cogs and sliding joints
Actually scrap the four piece idea it will be either a two piece motherboard for the front which will show off the haswell e build
Sandwiched in the middle piece of acrylic and then another sheet or motherboard tray for a back system
The graphics cards will still be using the angled custom bracket with pcie risers
Since quad graphics cards is a little absurd I am planning on three + a sound card rather than a pcie ssd however hopefully the rumored haswell e support up to ten sata three six gigabit per sec is actually the unreleased I believe Sata express so that the solid state drives can be pushed far beyond the limited access of their speeds
Motherboard concept designs are being developed though it is not the easy thing to express how a mosfet heatsink and chipset + plx heatsink will be like although I hope I can do it
In addition to that compatibility with watercooling is essential mineral oil cooling is far beyond my extent right now
Still hardly any news from neither the new cpu architectures but they had better smash some sense into amd
For ram low latency high density modules with large quantity is more needed
If there is a link to a drafted haswell e pdf please send it to me or put a link in the comments belows
I guess that is all my talk done for today on what I must cover up till May June or July
Hopefully my designs will be done by end of April early May then I can leap forward
0 Comments
