  • entry
    1
  • comments
    2
  • views
    1,003
Corsair H100i installation problems please help
Jason Jamelo
Hey guys, i have a COUGAR SOLUTION cpu case http://www.cougar-wo...solution.html
motherboard is 880GMS-E41 http://www.msi.com/p...MSE41_FX.html
The reason behind why I posted this, I'm planning to buy a CORSAIR H100i cpu cooler http://www.corsair.c...id-cpu-cooler . The problem was, I'm too hesitant if it's gonna fit perfectly with all the radiators and fans attaches to top of my CPU CASE or not, because the positioning of my MOBO's RAM is too high, its like inches away until it reaches the top of the CPU CASE. I'm so obsessed of making my rig water cooled. I really want to make this happen. Please guys suggest me what's in your thoughts coz this is my first time to build my own gaming rig, so I have limited knowledge about these aspects. I will be very glad to read your comments and suggestion or even criticism ..hehe GOD SPEED!
> I included a photo of my rig below :)
2 Comments
Yip I'm with LeeToby on this one it will not fit at all unless you cut some holes in the top of the case and mount it on the top. I would just buy a new case that's what I done
