This is the review of the Shure SE215, not to be confused with the SE215LTD which is a variant of the SE215 introduced at a later date.
At first
Coming from basically using <$40 earphones i did not know what to expect from this. I was utterly disappointed in the how the earphones fit in my ears and how lackluster they sound, i really thought that the sounds quality would have dramatically changed after switching from low grade entry tier audio products. Low bass response, confused mid and highs.
Which leads to the next point, after a period of 5 months, i learnt how to use the included foam and silicon tips properly to obtain a great seal, the included silicon tips provided provide a balanced sound and as i would like to rate it 7/10 in terms of noise isolation and with the included foam tips, 9/10 in terms of noise isolation. (Medium sized comply eartips are 8.5/10)
After my stock cable was damaged with the right side being faulty, i replaced the stock cable with the FiiO RC-SE1 replacement cables.
I found these to be more detailed and less warm in terms of audio quality than the stock cables, with slight but noticeable treble boosts probably because of a higher Silver content in the SPC(Silver plated copper) wires.
However, the micro-phonics on this particular cable are downright atrocious. If the stock cables would have 7/10 in terms of micro-phonics, these new replacement cables would have gotten a 1/10.
I straight up discourage anyone who gets annoyed easily when music is not playing and the cables rubs with each other. Otherwise, when playing music the micro-phonics can barely be heard and the cable is of great quality and certain to last for a long time.
I am going to try out the ATH E40s in a few weeks time and maybe i can provide a comparison of that when i get myself on them :D.
0 Comments
