  • entries
    5
  • comment
    1
  • views
    1,553
Fall Cleaning: Vintage Storage & Parts
PaintChips
This post might be more popular with the older crowd. Many of these items were in a moving box within smaller boxes, this ended up being a mess to sort through for disposal and potential re-use. Decided upon less photos as some vintage computing users might go nuts seeing a stack of 5.25 floppies in a disposal pile. I don't throw out failed 5.25 floppies, they're re-used for art or custom CD cases for indie bands.
Found a box of floppies in various sizes, if I recall that 3M 500K floppy was from a set of disks I used in childhood sometime around the C64/Apple II era and those McAfee VirusScan disks were when my school had a virus outbreak in their Novell WordPerfect PC lab--why I kept that floppy set, they can be erased and reused like I've done with past AOL floppies. In another bin I had even more Double-Density 720K floppies that are packed to be shipped to the UK, a friend still uses my old Amiga 1200.
It was common to use portable HDD cartridges by SyQuest which were really Conner platters in a cartridge with just a single usable magnetic side, the EzFlyer 135 MB was designed to compete with the Iomega Zip and the 230 MB drive made removable storage affordable($30 back in 1996, 135 MB cartridges were reasonable at $15). SyQuest drives were unique as they ran between 3200-4000 RPM depending upon the series/generation(they made 5.25" & 3.5" cartridge drives), plenty fast enough for MIDI synth audio banks/recording your own mix arrangements, in graphic design they were common to transfer files without lugging a heavy external SCSI or Parallel Port HDD around, I actually used cartridges to boot minimal installs of DOS+Windows and MacOS 7.6(PowerMac 7300) if I needed to run a program which wanted more memory.  Reliability of SyQuest pre-SparQ were reasonable, however the SparQ like SyJet was prone to head crashes destroying any inserted storage media which were just as bad as Iomega's Zip click-of-death killing Zip cartridges--SyQuest went bankrupt in 1998, ex-SyQuest engineers later formed Castlewood to release the Orb which suffered a similar reliability nightmare.
An old 1GB Western Digital drive, last I recall this drive was pulled from my 486 in 1997 and last spun up in 2002 in a Pentium III... more of a desk paperweight which I originally planned to reuse the platters for a turbine project. Drives after 2003 shifted to glass platters, I think Western Digital was the last to stop using metal platters--encountered a few 80-120GB drives with older platters built in 2004.
When the underside of drives were still exposed and at risk of damage if you weren't careful...
30-Pin RAM: Haven't actively supported any system using this RAM since 2002, these are my leftover test bench sticks. At one point I had over 80 1MB sticks, thankfully vintage computing allowed that stockpile to shrink. Most unlikely clients I've had were Ham Radio operators using old systems for custom controllers handling automated analog/digital recording deck solutions.
0 Comments
