  • entry
    1
  • comment
    1
  • views
    930
Need Help choosing a laptop
Nestorrd91
Hi, I have an Alienware m17x R4 that used to be my main personal ´´workstation/gaming´´ pc but I want to sell this giant laptop and buy a portable laptop because I build a powerfull desktop for my 3d modeling work (I´m an architect). I´m thinking about the Dell XPS 13 or the Asus Zenbook UX303UB but. I want a good IPS screen, a well build machine, something that can run CS:GO or casual gaming with no problem and a decent battery. Which option you think is better than the other? Or should I go with a Macbook pro 13 and install Boot Camp to have the option to boot windows 10 ? I was thinking about the surface pro 4 too but I think the specs are not the best for that price. My budget is around 1300. I just want the best lightweight option.
1 Comment
Hi, I believe the ASUS ZenBook Pro UX501VW-DS71T 15.6-Inch UHD Touchscreen Laptop (Core i7-6700HQ, 16 GB DDR4, 512 GB Gen 3 PCIe x4 SSD, Nvidia GTX960M GPU) will
be a good choice for you, considering it is amazingly thin and runs off an I7-6700HQ. It is about 150 dollars over your budget sadly, but if you are able to fork out a bit more money,
it will suit you comfortably. With the 960 graphics card, it will handle games, such as CS:GO just fine. It has a 4K display, and I believe it comes with Windows 10. For a better
description, copy the product name, which I pasted, and go to Amazon and I think you know the rest. Just read the more detailed description. I mostly went over what you described
above. Hope I helped. Please let me know if I was any help.
