Search In
  • More options...
Find results that contain...
Find results in...
will Sapphire 8 gb gpu work with my 5I 4460 and asus z87 pro mobo
Arkinson
 Share
I have a asus z87 pro motherboard and want to up grade i have a 5 I, 4 core 4460 chip I play fallout 4 and now with my 2 gb gpu cant will this run or do i need to upgrade other components.
It'll be fine. Just make sure to uninstall the old drivers and reinstall the new ones
welcome to the Linus Tech Tips forums!
it'll work fine. you'll deffo need some drivers to it a best experience.
 Share
