PS4 to monitor to PC?
sanipig18
Good day everyone.. would like to ask.. i made something bellow but can't seem to figure if a VGA spliiter CABLE would work so i wouldn't have to unplug the VGA PS4 TO MONITOR. so just i could use the Computer...
 thanks!
You can also just download the Playstation Remote Play taht will allow you to play your Playstation from your PC streamed through your LAN.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
But i don't think my PC can handle the Graphics etc that my Ps4 can..
that's why i decided to go for a calbe ?
you wont use your PC for the graphical processing, thats all still done through the PS4 itself.
"Black Out"
ok thanks.. ill look that up on  google and how it works thanks!
Seems like i need a fast internet. and my internet isn't consistent ..
anyway thanks for the reply..
hope others can answer this.
What it i don't have an internet?
or my internet is slow...
maybe ill be needing that slippter after all..
it doesnt use internet to stream it to your pc....it goes ps4 router comp...your router is perfectly fine doing it over lan...its all local
it doesnt use your actual internet, it uses your LAN.. so it doesnt leave your place and network at your house.. so as long as you have a gig connection locally in the house, then you should be fine. Just download and try it.
"Black Out"
ok will try thanks guys.. some tutorials on google are very misleading
