is it okay mixing 8GB stick with 4GB
Solved by Jurrunio,
Yes you can do that, that's what my laptop's configured to work at stock.
Performance compared to just a single stick will go up before you exceed 8GB usage, of which performance will drop to the same as before.
AdityaSaraf ·
Posted in Displays2 -
gooseta ·
Posted in Troubleshooting5 -
Dareios-Gintoki ·
Posted in Troubleshooting6 -
1
220VoltsallCore ·
Posted in Displays9 -
7
xo33 ·
4
Linkinworm ·
Mortal_2077 ·
Posted in Graphics Cards2
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
