Search In
  • More options...
Find results that contain...
Find results in...
MSI B450 Tomahawk compatible with RTX 2070?
Ruttlik
 Share
Hello,
Quick question, is all of this compatible with eachother? I plan on buying all of this, already have some parts (besides CPU, GPU, motherboard and memory)
Specs:
Operating system: Windows 10 Home 64-bit
Memory: Corsair 16 GB DDR4-3000 CMK16GX4M2B3000C15
SSD: Crucial 240 GB SSD
CPU: AMD Ryzen 5 2600 3.4GHz
Storage: Western Digital 1 TB HDD
Graphic Card: MSI RTX 2070 GAMING Z
Motherboard: MSI B450 Tomahawk
Power supply: Corsair VS650
Case: Corsair Spec 01 Red
Yes
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
Yes, but for your own safety, get a better PSU.
Main system: i7 8700k 5Ghz / Asus Prime Z370-A / Corsair Vengeance 2x8GB 3000Mhz / Asus TUF RTX3080 / EVGA 750W GQ / Fractal Design Meshify C
On 11/23/2018 at 6:52 PM, lee32uk said:
Do yourself a favour and buy a better power supply.
Do you not think it can handle everything?
Can it explode or something? Or can it not handle the components?
Corsair VS is generally low quality PSUs, they're not made to handle high end components.
Not for a system like that. A Corsair CXM or Bitfenix Formula etc would be an improvement if you need a budget option.
Winter is Coming.
 Share
