Search In
  • More options...
Find results that contain...
Find results in...
Audio connector is stuck
darklord37
 Share
Hi!
I am having some problems with my front audio connector on my corsair570x pc case. When I plug something into the headphone jack, it gets stuck and in order to pull it out, I have to pull really hard. It is the same with the microphone port, any tips on how to fix it?
Motherboard: Aourus Gaming 5, CPU: Intel i7 8700k, GPU: Asus ROG Strix 1070ti, RAM: Corsair Vengence LED 3200 MHz, SSD: Samsung 850 EVO 250 GB, Cooler: BeQuiet Dark Rock 3. Case: Corsair 570x
You could use the back audio ports, but I imagine that is not a helpful solution to you..
One thing you could do is purchase just a simple 3.5mm extension cable that leave plugged in at all time and you just plug in/out your headphones (or microphone) in those extension cables.
Thank you!
 Share
