torn between a 2015 macbook air and a 2015 15inch macbook pro.
Solved by jonrosalia,
the MacBook Pro is a better option the AIR is very underpowered and if you plan on using it for more than basic web browsing its kinda useless and the air had the old non retina display the 2015 pro is retina has 2 thunderbolt 2 ports its better all around and I wouldn't pay more than $300-500 for any used air personally.
