Search In
  • More options...
Find results that contain...
Find results in...
"fanless" psu for 350W load
James Evens
 Share
Any recommendations for a "fanless" psu without coil whine? load will be around 350W (RX580 + ryzen 5 1600x). Ideally with long warranty which covers coil whine.
quick serach turned up these options:
Enermax Max tayatan 800W - 150€
sesonic platinum fanless 400W - 120€
SilverStone NJ520 520W -150€
sourcing a 135mm fan to repair the straight power 11 - ?€
Why not get something which doesn't turn fan until certain load?
For example my Seasonic X-650 is fully off until it power goes over around 170 watts ... that only happens when gaming and then the RX 570 fans make way more noise.
Plenty of power supplies that won't be noisy, you shouldn't focus that much on completely fanless power supplies.
replacing the fan should be fairly easy but double check that it's a 135mm fan and see if you can't use a 140mm fan (some companies don't use them because if i remember correctly there were some patents related to 140mm so they use 139mm or 135mm fans but the screw locations are basically in the same locations, or there's holes for multiple sizes.) Make sure you get the same or better flow of air with whatever new fan you use (check the cfm value)
Or get the RM550x which is nearly soundless?
Personal Desktop":
CPU: Intel Core i7 8700 @4.45ghz |~| Cooling: Cooler Master Hyper 212X |~| MOBO: Gigabyte Z370M D3H mATX|~| RAM: 16gb DDR4 3333mhzCL16 G.Skill Trident Z |~| GPU: nVidia Founders Edition GTX 1080 Ti |~| PSU: Corsair TX650M 80Plus Gold |~| Boot:  SSD WD Green M.2 2280 240GB |~| Storage: 1x3TB HDD 7200rpm Seagate Barracuda + SanDisk Ultra 3D 1TB |~| Case: Fractal Design Meshify C Mini |~| Display: Toshiba UL7A 4K/60hz |~| OS: Windows 10 Pro.
Luna, the temporary Desktop:
CPU: Intel Core i7 10700KF @ 5.0Ghz (5.1Ghz 4-core) |~| Cooling: bq! Dark Rock 4 Pro |~| MOBO: Gigabyte Z490 UD |~| RAM: 32G Kingston HyperX @ 2666Mhz CL13 |~| GPU: AMD Radeon RX 6800 (Reference) |~| PSU: Corsair HX1000 80+ Platinum |~| Windows Boot Drive: 2x 512GB (1TB total) Plextor SATA SSD (RAID0 volume) |~| Linux Boot Drive: 500GB Kingston A2000 |~| Storage: 4TB WD Black HDD |~| Case: Cooler Master Silencio S600 |~| Display 1 (leftmost): Eizo (unknown model) 1920x1080 IPS @ 60Hz|~| Display 2 (center): BenQ ZOWIE XL2540 1920x1080 TN @ 240Hz |~| Display 3 (rightmost): Wacom Cintiq Pro 24 3840x2160 IPS @ 60Hz 10-bit |~| OS: Windows 10 Pro (games / art) + Linux (distro: NixOS; programming and daily driver)
CPU: ninja 4 with two noctua a12x25
gpu: arctic xtrem 4
There is not much noise even under full load so getting rid of the fan is the best option. One fan bearing less to worry about.
170W is to low. 350W is the minimum i want.
 Share
