Search In
  • More options...
Find results that contain...
Find results in...
Zotac 1080 Ti Mini fan replacement
 Share
Hi,
i have second handed Zotac 1080 Ti Mini, but 100mm fan is clicking.
I have now 2 options, buy new cheap ones from AliExpress or use Arctic Accelero Xtreme IV.
Has anybody same card with Accelero installed or someone with better solution ?
I am from Czech Republic so my options may be little bit limited.
I also tried custom cooling using two 92mm fans from Arctic with PWM Y reduction and PWM to VGA PWM reduction from Gelid.
But temps were too bad almost 90C at max speed.
Use Morpheus II + 2xNF-F12 2000/3000rpm
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
  • 2 weeks later...
Hi, not sure if you already solved your problem, but just in case you can buy a spare 100mm fan here
I had the same problem with my 1080 mini, 100mm fan was making loud rattling noises, the replacement fan arrived today and it works fine
 Share
