Can I maintain 60fps with a overclock
Turtle Rig
I have not OCed a video card in a long long time.  One change I notice since long ago when OCing a card is it doesn't show your load clock speeds,  My nv panel is on optimal power,,,   When I choose performance it shows the full speed of the clock.  How do I OC this ?  Change to performance mode and OC, or leave it on optimal power and OC that way, in which case I wont know my real clock speeds... sighs..  Also do I need to touch voltage on this thing.  I just want my lowest FPS which is 48fps every blue moon in QC.  Will OCing change that lowest fps drop 48 to like 55 or 60fps ?
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
Just stick to optimal power. To do your overclock with frequency updated you will need a GPU demanding game running at the same time (GPU actively rendering, that is) while you tune the clock speeds. To ensure GPU bottleneck, crank up the graphics settings as much as possible as long as it doesnt exceed VRAM limit.
Desktop benching:
Gotcha!  thanks Jurrunio much!!!
Can I take up the core clock and memory clock by 50mhz each without touching voltage.  I want a safe overclock ya know.
Lazy mode (pulling slider) or pro mode (voltage/frequency graph)?
I'd rather do it in 25mhz intervals.
Desktop benching:
I'd start with +100 core and +300 memory, those shouldn't cause any instability. Then start taking doing 10 mhz intervals on the core and 25 mhz intervals on the memory till it starts crashing. I would suggest using furmark for max stress and then playing some games to confirm stability. I would figure that you could do about +175 core +500 memory at your max overclocks on that card, don't bother adjusting voltage cause it doesn't really make a difference on pascal.
Edited by TheDankKoosh
8086k Winner BABY!!
Main rig
CPU: R7 5800x3d (-25 all core CO 102 bclk)
Board: Gigabyte B550 AD UC
Cooler: Corsair H150i AIO
Ram: 32gb HP V10 RGB 3200 C14 (3733 C14) tuned subs
GPU: EVGA XC3 RTX 3080 (+120 core +950 mem 90% PL)
Case: Thermaltake H570 TG Snow Edition
PSU: Fractal ION Plus 760w Platinum
SSD: 1tb Teamgroup MP34  2tb Mushkin Pilot-E
Monitors: 32" Samsung Odyssey G7 (1440p 240hz), Some FHD Acer 24" VA
GFs System
CPU: E5 1660v3 (4.3ghz 1.2v)
Mobo: Gigabyte x99 UD3P
Cooler: Corsair H100i AIO
Ram: 32gb Crucial Ballistix 3600 C16 (3000 C14)
GPU: EVGA RTX 2060 Super
Case: Phanteks P400A Mesh
PSU: Seasonic Focus Plus Gold 650w
SSD: Kingston NV1 2tb
Monitors: 27" Viotek GFT27DB (1440p 144hz), Some 24" BENQ 1080p IPS
8086k Winner BABY!!
Main rig
GFs System
Wow dankboy you rock..  :)  Ok so I launch a game then task out and Im gonna raise the core +100 and memory +300.  Am I correct ?  About to do it just wan't confirmation.
You can apply the overclock before launching a game. MSI Afterburner remembers your settings. You can even apply overclock on startup of MSI Afterburner, and just enable MSI afterburner to start with windows = Overclock on 24/7 :)
Main:  1650 v2   @ 4,6GHz   -   X79 Deluxe                -   GTX 1080 @ 2000MHz   -   24GB DDR3 @ 2400MHz / CL10
Side:   i7-4790K @ 4,5GHz   -   Maximus 7 Hero        -   GTX 1070 @ 2114MHz    -  16GB DDR3 @ 2666MHz / CL12
HWBOT
Yes boss, I have AB launched at all times, so the clocks will kick in at boot up.  Im in optimal power mode AB shows me low mhz numbers, so like I said, I guess I have to launch Quake Champions then task out and change core +100 and memory +300 ......, hope that makes me lowest fps of 48 to 55 or 60 sighs,,,
That power setting in the Nvidia Control Panel only affects idle clocks. If you keep it at optimal, the frequency will stay low for best temperatures. If you put it to performance mode, the idle frequency will be the cards base clock 24/7. This doesn't affect anything in games, so keep optimal over performance for lower temps and lower clocks so the card can rest easy at idle.
I'm sure you can do +400 or even +500 memory stable on any pascal card. Keep voltage slider at minimum, and push power & temp limits to max. That voltage slider also doesn't affect anything in gaming other than giving you higher temps. The voltage slider is mainly for lower clocks.
HWBOT
