Search In
  • More options...
Find results that contain...
Find results in...
I would like to know if this is normal or no my cpu temp is low temps?
Go to solution Solved by asand1,
Op is not worried about being to hot. He is worried about being too cold.
With good cooling and good airflow 50c is typical. My X5680 @ 4Ghz only runs at 45-50c.
Hello i have a ryzen 5 1600x with an msi core frozr l cpu cooler and 2 front intake fan and 1 top exhaust and 1 back exhaust fan i was playing assassin's creed odyssey for about 2 hours and i see my temp never go over 51-53 degree so is this normal or no i mean should the temp go more than this or it is normal to have this temperature because i see that the ryzen will get hotter than this in the reviews so is this because of the cooler that i have and should i see if the utilization is working fine. I dont know what to do and if everything is working fine for me and thank you.
Pc specs:
Gyx 1070 founders edition
Ryzen 5 1600x
Hyperx fury ram ddr4 16gb 2666mhz(8gbx2)
50 is fine
If you're worried about it not performing right, look into your cpu usage
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
No issue here
I might not know what I'm talking about but I'm gonna say it anyways
Try using the PSU Tier List!
How to reset the bios/clear the cmos
My current rig: Gigabyte Aero 15W v8-BK4 15"
CPU: Intel i7 8750-H 6-core
Ram: 1x16gb DDR4 2666 mHz
Storage: 512 m.2 nvme ssd
GPU: GTX 1060 6gb
Monitor: 23.8" Dell S2417DG 144hz g-sync 1440p + 27" Acer S271HL 60 Hz 1080p
Keyboard: Corsair Strafe RGB Cherry Mx Silent
Mouse: Logitech G502 Proteus Spectrum RGB, Steelseries Rival 600
Headset: Philips SHP 9500 + Sennheiser hd598
Dac/Amp: Monoprice liquid spark (amp) + topping d10 (dac)
50 is a good temp
hitting 85 and above is where you should start to worry about.
Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB
            CPU: Ryzen 9 5900X          Case: Antec P8     PSU: Corsair RM850x                        Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM
            Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition
27 minutes ago, Slottr said:
50 is fine
I know it is fine but i think that it should get hotter while playing games or no? I think that tje 50's is still cold for a cpu while gaming i mean i want to know of the cpu is running fine
Guys the probpem is not with the temp i wamt ro know why my cpu is so cold while gaming because i know that the ryzen 5 1600x will get hot while gaming but mine it doesn't so i need to know if it is working fine or no and maybe this temp is because of my msi cooler frozr l cpu cooler?
50c is a good temp. I get to 66 max when stressing my 1700.
How does cpu usage look in game?
Your temps while gaming with that CPU is safe in the 70's c.  I do mean safe, as nothing bad will happen.  A CPU is supposed to get hot, 53c while gaming is excellent temp.  Wait til you get into 70's c then message us, other then that your fine.  Have fun
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
Black Knight-
Ryzen 3600X, MSI B450-A Pro, 32Gb Corsair Vengeance LPX 3000mhz, Gigabyte RX 5700,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
Dell Optiplex 3010, Xeon E3 1270 V2, 16GB Patriot Viper 1600Mhz , Silicon Power A55 512GB SSD, Sapphire Pulse RX 570, Corsair CX430
How to see cpu usage in games? In hwmonitor it say the cpu utilization is some cores 100% and other 80 or 90% not below this and sometime in games all will be 100% this is the max value don't know while gaming how they are behaving
If WHinfo says 100% then no worries about not performing. Running cool under load is a good thing.
Black Knight-
Daughter's Rig;
 Share
