Wireless Earbuds for Oneplus 6T?
IsaacThePooper
I'm about to get a Oneplus 6T and I've been looking for wireless earbuds on Amazon.
I found these two that are pretty compelling:
https://www.amazon.com/Wireless-Kissral-Bluetooth-Headphones-Case-Black/dp/B07HKYGBT8/ref=sr_1_2_sspa?ie=UTF8&qid=1542690656&sr=8-2-spons&keywords=wireless+earbuds&psc=1#customerReviews
https://www.amazon.com/dp/B07JJL4HSN/ref=psdc_172541_t1_B07HKYGBT8#customerReviews
Which one do you think is better for the price/battery life?
Do you have any other suggestions?
I have the OnePlus 5t and paired with the OnePlus Bullets wireless and I absolutely love the OnePlus duo. :)
CPU: Intel I5-7500
CPU Cooler: Cooler Master ML240
Motherboard: ASRock B250M PRO 4
Memory: 16GB Patriot Viper Elite
Gpu: Asus Dual 1060 3GB
Storage: Corsair 120GB M.2 NVME
500GB Samsung 860 EVO
1TB WD Blue
Power Supply: EVGA 500W 80+Bronze
Case: Phanteks P350X
Monitors: HP Omen 25in 144hz
and some 25in Acer
Keyboard: Corsair K70 LUX RGB
Mouse: Corsair M65 Pro
Headphones= VModa Crossfade Wireless(but used wired)
Speakers: Some janky speakers I jerry-rigged
It's a bit more expensive and they still have a wire, but it still looks pretty compelling.
They don't fit in its provided case but that doesn't bother me because they're so light I just wear them all the time, the charging is insane. To me they were totally worth the $69, if you don't want those then I would look at the Anker SoundBuds Slim+ they sound pretty good as well.
CPU: Intel I5-7500
1TB WD Blue
and some 25in Acer
