Search In
  • More options...
Find results that contain...
Find results in...
Asrock Z370 Extreme4
lmeneses
 Share
This board is currently on sale for $110, but the sale ends tomorrow. Should I snag it or do you guys think there'll be a better deal on Black Friday and Cyber Monday? Will be paired with an i5-8600k
https://www.newegg.com/Product/Product.aspx?Item=N82E16813157789
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
If you get the rebate too it's a really good deal. I would go for it.
that board with 8600k is a good match, though the price probably won't go up before thanksgiving, theres no risk in waiting.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll evga non-3090 tie ftw3 1905 0.8v 65C 270w (double fps of 1080ti) ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll all nf12/14 fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll x27 ll PA272w
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666  bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA non-30 tie XC 1830//7600 0.85v 210w ll  8x nf12/14 fans 2x samsung 860 evo 500gb raid 0 ll 500gb nvme 970 evo ll Corsair graphite 780T ll EVGA P2 1200w ll Windows 10 Pro ll NEC PA242w (movie, work mon dying) 1080p 60hzll Predator X27 4k144 hdr (using at 4:4:4 98 fan is dying)
the sale ends in 13 hours thooooooo
is it a good deal? yes, is it an AMAZING deal? probably not, i grabbed that board a year ago for 140, it's now a year and a gen later, your call :)
lmao ugh, all right, I shall waittttt
if it makes you feel better, hardware unbox did reviews on all the z390 motherboards, gigabyte seems to have gone the extra mile this gen
even their 120usd board has a 10+2 vrm, not even on sale.
https://www.newegg.com/Product/Product.aspx?Item=N82E16813145095&Description=z390 gigabyte&cm_re=z390_gigabyte-_-13-145-095-_-Product
oh, hmmm, I would get that one if it wasn't so ugly lol
I would suggest buying it. Its the one I have planned on. @Firewrath9 is right though, the z370 is a great board though the only tradeoff is not having any rgb headers. EVGA has sales every Wednesday too.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
oh, wank, so I wont be able to use rgb fans with it ? And the only concern is that there are no returns :/
You can use rgb fans that have their own separate controller but you can't use a program within the pc to control and sync up the fans and other stuff, etc. Check what kinf of header the extreme4 has though
8086k
aorus pro z390
evga 3070 ultra
oh, idk if the rgb fans I am planning on buying have that. Lemme check lol
You can use software, just not motherboard software, rgb can connect thru USB 2.0 ports.
oh yeah I completely spaced that.
8086k
aorus pro z390
evga 3070 ultra
 Share
