PC not working as it supposed to be for 3 years
Ciupz
1 minute ago, Ciupz said:
If it's not software are you sure your machine just isn't overheating?
6 minutes ago, Ciupz said:
So, I have my rig for 3.5 years and it's always been the same. I couldn't ever figure out why or what caused it, and I stumbled upon this forum so I thought you guys might actually find a solution!
As a little explanation : When I first got my PC I saw that the fps was below expectations without really any reason. benchmarks were good, parts were new, got them from a big pc parts store.
I second this ones idea @Streetguru check the temps, voltage, fanspeed with MSI afterburner and then come back to us with your conclusion testing in multiple scenarios.
Good luck and write down your info as well.
You expect me to reply then you'd best QUOTE me so I can........thanks
                                           Simple PC Parts list to reference for other Users:
Case: Meshify C
CPU: Ryzen 1600 @ 3.8
Mobo: ASRock AB350 Pro4
Ram: 2 x 8gb (Corsair RGB Pro)
GPU: XFX RX 580 8gb - Clocks: Core @1386mhz, memory @2000mhz
Storage:
Boot drive - 120gb NVME Corsair MP500
Main Storage drive - 500gb 860 EVO
Archival/Backup drive - 2TB Black WD
Mouse: Logi M570 for work, and a G502 for gaming
PSU: EVGA Supernova G2 650 80+ Gold
OS: And of course Win 10 Pro, because Linux ain't fully baked yet.
Monitors: (27in monitors)
TN - VG278Q @144hz
IPS - VP279Q-P @60hz
I uploaded 2 imgur screenshots that I guess went unnocited, GPU 60*C and CPU 50*C is not overheating
3 minutes ago, Zmax said:
Up memory to at least 16g frame will improve
Yeah man that always was an option but you cant tell me that with 8gb of ram KILLING FLOOR ONE would be running at 30 fps
Huh I'm stumped as well then, damn. That stinks mate.
Case: Meshify C
Storage:
TN - VG278Q @144hz
8GBs of RAM is plenty for gaming
no idea what could be the issue then, maybe those games just run poorly?
I doubt anything related to temp affects it,
its just a gtx 970 / i5 4460,
when overheating, they just go back to stock base clock, and not any lower.
I had an i5 2500 and stock cooler not installed properly and had idle temps at 80C for 2 years. I didnt notice performance drop.
same as my gtx970, clock doesnt do below 1342mhz when overheat
so I played dozens of games over the years and every. single. one. of. them. was made poorly? I realllllllllllly dont think so. every mmo I ever played with this rig is laggy, not unplayable but laggy.
I played goddamn LINEAGE2 a few months ago and I had low fps on the main town where they were many shops/ppl. lineage2
Then something is probably wrong with your GPU mostly assuming CPU scores are normal in like cinebench and whatever.
But there's really no cheap decent upgrade yet, unless you want a $200 RX 580 that comes with Resident Evil 2 remake and devil may cry 5
or for some strange reason your PSU is the issue, but that should cause crashing, not any performance issues.
do you think its the "new" gpu drivers again?
it has been reported some Nvidia drivers lowers performance of old gpu
you say that the GPU is the problem, okay.
but let me show you my last benchmarks that I did 2 days ago image.png.23a1473af832aeccab8fe32c95f8b071.pngimage.png.3fe37a3606ff3b42f0aed8c8b05badf0.png
These were with userbenchmark. now, with 3D Mark : image.png.e17a0d6ec3d2376a67597a33aa113754.png
On both of them it says that my rig works either above expectations or it has a good score. how can I certainly say that it is the gpu then ?
I had an older driver up till now (390~), when I randomly updated my gpu out of curiosity. no difference
No idea then, extremely rarely a failing hard drive may cause slow down but probably not for 3 years.
I suppose it could be the single channel RAM, but that shouldn't matter in most cases.
I would blame the GPU first since that's the thing that runs the games mostly...but if benchmarks are normal then I have no idea
mini update: I just checked my bios version, and it said that is the last one ( got @biosliveutility ). in case that any1 wanted to say that my bios needs an update.
Are you maybe using your PC with a monitor/TV with a really low refresh rate?
How about the checking the refresh rate in your Nvidia control panel as well.
I had one system that would sometimes change the refresh rate to 30hz for some reason when I ran retro games and would not change back until I did it manually. You can find this setting right where the custom resolution options are in the nvidia control panel to the right of the box where you select resolutions.
Your scores seems to be a tiny bit low, comparing other Time Spy 1.0 results from other i5-4460 and GTX 970 users.
I am seeing CPU scores in the range of 2800 ~ 2900 for other i5-4460's.
You are only getting 2559.
GPU score looks okay.
That will vary a bit depending on the GPU Core and Memory clocks.
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz
  • Gigabyte Z390 Aorus Master
  • Sapphire NITRO+ RX 6800 XT S.E + EKwb Quantum Vector Full Cover Waterblock
  • 32GB G.Skill TridentZ DDR4-3000 CL14 @ DDR-3400 custom CL15 timings
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO +  500GB Samsung 980 + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Lian-Li O11 Dynamic EVO XL
  • Ekwb Custom loop + 2x EKwb Quantum Surface P360M Radiators
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
so is it fair to say that I might've gotten unlucky with my cpu and it has a malfunction from the producer?
I dont even wanna start man. if you dont read the post, dont reply. how would I not be aware of having a lower refresh rate monitor? ffs
I don't make assumptions.
I've met many people who needed troubleshooting help who were using things like TV's instead of monitors and whatnot. I also gave you another tip there to check your Nvidia control panel to see if the refresh rate got halved like it does sometimes after running really old programs.
Anyways, I understand that you're frustrated, but no need to be rude.
With troubleshooting, 90% of the solutions are basic things like this so I would never be so quick to assume someone hasn't thought of something like that. All troubleshooters will run through a list of things starting with the most common, most simple suggestions.
It could be, but we don't know for sure at the moment.
What version motherboard BIOS are you using?
If your BIOS is very out-of-date, you may also try updating it.
Latest version for GA-B85M-D2V (rev 1.1) is BIOS F7 from August 21 2015.
UserBenchMark does not show the actual CPU frequency.
Run CPU-Z while in-game, and check the CPU speed -- upload s screenshot of CPU-Z, too, if you can.
The i5-4460 SHOULD run at 3.2 GHz, and boosts up to 3.4 GHz if temperature / workload allows.
If you see it dipping below ~3.2 GHz, something is wrong.
AMD Ryzen Rig
  • AMD R7-5800X
in Maple Story 2. if its needed to be tested in other games I will, but I feel like one is enough.
Also, how can I check the current bios version ?
Hmm... CPU-Z result looks okay there... 3.2 GHz, 4 cores, and 4 threads...
You can check the BIOS version, either in the BIOS menu itself, or the 'Mainboard' tab within CPU-Z.
AMD Ryzen Rig
  • AMD R7-5800X
this is the mainboard tab. so I guess the bios is outdated. if so, how do I update it? afaik if the update goes wrong, it screws up the whole system.
You need to download the BIOS file, unzip it, and copy it onto a USB stick.
There should then be a BIOS updating/flashing menu within the BIOS.
99% of the time, if you do not accidentally power off the computer mid-way through a BIOS flash, you are completely safe.
It can take a few minutes to update the BIOS -- the progress bar can be not moving at certain points -- but just be patient.
The step-by-step instructions on how to update your BIOS should be in your motherboard user manual.
You can get the online / digital version of the manual here:
https://www.gigabyte.com/Motherboard/GA-B85M-D2V-rev-30#support-dl-bios
Your motherboard has three different revisions... rev 1.1, 2.0, and 3.0.
Find out which on your board is; motherboard box should indicate it...or you can look directly on the motherboard itself
AMD Ryzen Rig
  • AMD R7-5800X
